  • Marinco 8215T NEMA Hospital-Grade Power Plug 15A 125V Clear
CLEARANCE Marinco 8215T NEMA Hospital-Grade Power Plug 15A 125V Clear
MarincoPart # 110-402
Model: 8215T
This hospital grade plug is perfect for the replacement or building your own audiophile grade power cords. Meets or exceeds hospital grade (green dot) UL tests. Perma-Lock Terminals actually "lock up" the screw’s threads therefore heat and vibration cannot loosen the screw.
Marinco 8215 NEMA Hospital-Grade Power Plug 15A 125V Black
Price: $11.98Part # 110-403
See all items in AC Power Connectors
CLEARANCE $13.49
MSRP: $20.99
Save $7.50 (36%)
Only 3 In Stock
We'll send you an email when Marinco 8215T NEMA Hospital-Grade Power Plug 15A 125V Clear is back in stock or available for preorder.
Order in the next 4 hr 9 min to ship today. Details
This hospital grade plug is perfect for the replacement or building your own audiophile grade power cords. Meets or exceeds hospital grade (green dot) UL tests. Perma-Lock™ Terminals actually "lock up" the screw’s threads therefore heat and vibration cannot loosen the screw creating a superior low resistance connector. The Marinco Mag-Vu™ Windows allow for fast verification of terminal connection through transparent /magnifying connector bodies. Plugs are rated for up to 15A and can accept up to 12 gauge wire.
BrandMarinco
Model8215T
Part Number110-402
UPC649075801404
Weight0.1
ConfigurationNEMA 5-15 Edison
Current Rating15A
Power Connector TypeCable Mount
