Marantz's PMD-300CP is a dual-well cassette recorder/player that features two speeds of dubbing and a USB output to digitize tape contents to computer for archiving. Two DC servo motors ensure stable, consistent speed for accurate recording and playback. This is the ideal unit to convert a valuable cassette tape collection into digital files.
Specifications: • Frequency response: 40 - 14,000 Hz (±3 dB, -20 dB recording level, standard tape media); 40 - 15,000 Hz (±3 dB, -20 dB recording level, chrome tape media) • Signal to noise ratio: 58 dB • Wow and flutter: < 0.2% (DIN45500) • Crosstalk: 40 dB (1 kHz) • Channel separation: 40 dB (1 kHz) • THD: < 1% (1 kHz, 0VU 3rd H.D. normal tape) • Input impedance: 50,000 ohms • Output impedance: 5,000 ohms • USB audio interface: USB 1.1 compatible; 16-bit; 44.1 or 48 kHz • Supply voltage: 120 VAC, 60 Hz • Weight: 8.5 lbs. (4 kg) • Dimensions (with rack ears): 19" x 8.5" x 5.3" (483 x 215 x 135 mm).
