  • Mackie Onyx Producer 2•2 2x2 USB Audio Interface with MIDI
CLEARANCE Mackie Onyx Producer 2•2 2x2 USB Audio Interface with MIDI
MackiePart # 249-616
Model: Producer 2•2
Read 1 Review or
Combining high-resolution 24-bit/192kHz converters with premium Mackie analog circuit and Built-Like-A-Tank™ hardware design, the bus-powered Onyx™ Producer 2-2 is perfect for singer-songwriters, content creators, and mobile recording. The Producer 2-2 features dual Onyx mic pres with phantom power, Hi-Z instrument switches plus zero-latency direct analog monitoring. Full MIDI I/O allows for connection of controllers, synths, and more.
  • Two boutique-quality Onyx™ mic preamps with class-leading fidelity and dynamic range
  • Zero-latency direct monitoring of analog inputs
  • Dedicated outputs for connecting studio monitors
  • MIDI I/O for connecting synths, controllers and more
  • Bus-powered for easy mobile recording with no power adapter needed
  • Built-Like-A-Tank™ design to survive day-to-day abuse
  • Tracktion™ Music Production Software + DAW Essentials Collection Plug-Ins Included
We'll send you an email when Mackie Onyx Producer 2•2 2x2 USB Audio Interface with MIDI is back in stock or available for preorder.
Combining high-resolution 24-bit/192kHz converters with premium Mackie analog circuit and Built-Like-A-Tank™ hardware design, the bus-powered Onyx™ Producer 2-2 is perfect for home studios, mobile recording, and dual mic applications. Featuring two XLR/TRS combo inputs with Onyx mic pres, each is equipped with phantom power and Hi-Z instrument switches for maximum versatility. Plus, with zero-latency direct analog monitoring ensures you can always hear yourself in real time. It also has built-in MIDI I/O for controllers, synths, and more. With the Onyx Producer 2-2, you have the power to capture your performance and experience media with pristine fidelity at home or on the go. Your Creativity Without Limits – Onyx Series USB Audio Interfaces.
•Channels: 2 inputs, 2 outputs
•Inputs (Mic): 2
•Inputs (Line): TRS x 2
•Outputs: TRS x 2
•Headphones: 1/4" x 1
•Phantom Power: yes
•MIDI: In, Out
•Digital Connectivity: USB 2.0
• Dimensions: 7.3" W x 4.4" D x 1.9" H
• Weight: 1.3 lbs.
BrandMackie
ModelProducer 2•2
Part Number249-616
UPC663961053166
Weight2.1
