  • Mackie MDB-USB Stereo Direct Box
CLEARANCE Mackie MDB-USB Stereo Direct Box
MackiePart # 249-620
Model: MDB-USB
With the bus-powered MDB-USB Stereo DI, the days of relying on your headphone jack to get audio from a computer into analog gear are over. Combining a high-resolution audio interface with a noise and distortion-free stereo DI, MDB-USB converts your digital audio into clean, balanced, stereo output. Featuring an output level control, headphone output, and mono sum for maximum versatility. Analog outputs are dual XLR with ground lift.
  • Connect your computer directly via USB
  • High-resolution 24bit/96kHz interface
  • Output level control with Mono switch
  • Headphone output for easy monitoring
  • Noise-free operation
  • Plug and play operation, no driver required
  • Built-Like-A-Tank™ construction
CLEARANCE $179.99
4 In Stock
We'll send you an email when Mackie MDB-USB Stereo Direct Box is back in stock or available for preorder.
Order in the next 8 hr 57 min to ship today. Details
• Dimensions: 3.4" W x 1.5" D x 5.8" H
• Weight: 1 lb.
BrandMackie
ModelMDB-USB
Part Number249-620
UPC663961054019
Weight1.5
Rack MountableNo
