  • Mackie M48 48V Power Supply
CLEARANCE Mackie M48 48V Power Supply
MackiePart # 249-621
Model: M48
The M48 48V Phantom Power Supply allows you to use your devices and microphones that require external power in any setup. Sometimes the phantom power being supplied is inadequate as well, and with the M48, you will always get a clean, full 48v of power for the best sound and noise performance. Powered by either a 9V battery or supplied AC adapter.
  • Perfect for condenser mics and equipment that require 48V Phantom Power
  • XLR input and output
  • Transparent, noise-free operation
  • Powered by the included AC adapter or 9V battery
  • Power and Low Battery indication
  • Built-Like-A-Tank™ construction
CLEARANCE $69.99
1 In Stock
We'll send you an email when Mackie M48 48V Power Supply is back in stock or available for preorder.
The M48 48V Phantom Power Supply allows you to use your devices and microphones that require external power in any setup. Sometimes the phantom power being supplied is inadequate as well, and with the M48, you will always get a clean, full 48V of power for the best sound and noise performance. Powered by either a 9V battery or supplied AC adapter.
• Dimensions: 3.4" W x 1.5" D x 5.8" H
• Weight: 0.8 lbs.
BrandMackie
ModelM48
Part Number249-621
UPC663961054033
Weight1.45
