  • Mackie Install Rack Mount Kit Extended Front and Rear Rackmount Brackets for DL32R
CLEARANCE Mackie Install Rack Mount Kit Extended Front and Rear Rackmount Brackets for DL32R
MackiePart # 249-659
Model: DL32R Install Rackmount Kit
The official rack mount bracket kit for your DL32R mixer, allowing the mixer to be recessed back into the rack and providing rear support brackets.
  • Custom designed for the Mackie DL32R digital mixer
  • Mount your mixer in a portable case with the rest of your gear
  • Recesses the DL32R in to the rack so connections can remain when closing the case.
  • Rear rack supports for extra stability in rack up to 24" deep
  • Heavy-duty metal construction
CLEARANCE $59.99
1 In Stock
We'll send you an email when Mackie Install Rack Mount Kit Extended Front and Rear Rackmount Brackets for DL32R is back in stock or available for preorder.
Easily and securely mount your DL32R mixer in a standard 19" equipment rack with this rackmount kit. The recessed rack ears allow connections to be made to the front of the mixer in an rack with a lid or a closing front door. Rear adjustable rack brackets provide additional support in permanent installations, or heavy duty touring.
BrandMackie
ModelDL32R Install Rackmount Kit
Part Number249-659
UPC00663961047301
Weight3
