  • Mackie 1642VLZ4 16-Channel Compact 4-Bus Mixer
CLEARANCE Mackie 1642VLZ4 16-Channel Compact 4-Bus Mixer
MackiePart # 249-572
Model: 1642VLZ4
The 16-channel 1642VLZ4 features 10 Mackie flagship Onyx mic preamps in a compact 4-bus design with the high-headroom/low-noise performance you demand for your application. With a proven feature set that includes flexible mono/stereo channels perfect for live sound, the 1642VLZ4 is a "Built-Like-A-Tank" compact mixing solution.
  • 16-channel mixer featuring Mackie signature high-headroom/low-noise design
  • 10 boutique-quality Onyx mic preamps
  • 4 aux sends, level, pan and PFL solo on each channel
  • Phantom power for condenser mics
  • Improved RF rejection perfect for broadcast applications
  • "Built-Like-A-Tank" rugged steel chassis with powder-coat finish
  • High-visibility, high-contrast controls deliver convenient "at-a-glance" visual feedback
We'll send you an email when Mackie 1642VLZ4 16-Channel Compact 4-Bus Mixer is back in stock or available for preorder.
The 16-channel 1642VLZ4 delivers the proven performance of Mackie Onyx mic preamps in a compact 4-bus mixer design perfect for bands, clubs and more. From every input to every output, the 1642VLZ4 is designed to provide the highest headroom and lowest noise possible for maximum signal integrity. Plus, it is truly "Built-Like-A-Tank" with a ridiculously rugged solid steel chassis that includes high-contrast controls for ultimate tactile control. And with features like an expanded return section for no-hassle system integration plus a dedicated control room section, the 1642VLZ4 is the go-to mixer choice for any application that demands flexibility and professional performance.
Features:
• Ultra-wide 60 dB gain range
• 128.5 dB dynamic range
• +22 dBu line input handling
• Extended frequency response
• Distortion under 0.0007% (20 Hz - 50 kHz)
• Phantom power for studio condenser mics
• 16 high-headroom line inputs with +4/-10 operation control
• 8 balanced inserts perfect for integrating outboard gear
• 18 dB/oct 75 Hz low-cut filter on mic input channels
• 60mm long-wearing log-taper faders
• 4 stereo returns, 8 direct outs and 4 group/bus outputs
• Control room / phones source matrix
• High-resolution 12-segment stereo meters
• Sealed rotary control resist dust and grime
• Rack-mountable design using optional rack ear kit
• Multi-voltage power supply for worldwide use
• Type: Analog
• Channels: 16
• Inputs (mic): 10
• Inputs (line): TRS x 16, RCA x 2
• Outputs (main): XLR x 2, TRS x 2, (Mono) TRS x 1
• Outputs (other): (Subgroup) TRS x 8, (CR) TRS x 2, RCA x 2
• Direct Outputs: Channels 1-8
• Channel Inserts: Channels 1-8, Main L/R
• Aux sends: Pre/Post x 2, Post x 2
• Send/ Return: (Send) TRS x 4, (Return Stereo) TRS x 4
• Headphones: 1/4" x 1
• EQ: 3-band sweepable mid (80 Hz, 100 Hz - 8kHz, 12 kHz) w/ low cut filter (75 Hz)
• Phantom power: yes
• Dimensions: 16.6" W x 16.7" D x 5.2" H
• Weight: 18.2 lbs.
BrandMackie
Model1642VLZ4
Part Number249-572
UPC663961039726
Weight23.5
Mixer TypeAnalog
XLR Mic Inputs10 to 15
