  • M3 x 16mm Machine Screw Black Oxide - 100 Pcs.
CLEARANCE M3 x 16mm Machine Screw Black Oxide - 100 Pcs.
Parts ExpressPart # 081-3203
M3 x 16 mm machine screw, perfect for installing "D" style connectors from Neutrik, Switchcraft (EH style), Amphenol and others in rack panels, cabinets, and more. Flat heads sit flush with the flange for a clean finished look. Available in zinc or black finish, and 10 or 16 mm lengths to suit different applications. 100 pieces per package.
  • Specified for Neutrik D connectors
  • Flat head sits flush with your connector
  • 16 mm length for applications where more depth is required
We'll send you an email when M3 x 16mm Machine Screw Black Oxide - 100 Pcs. is back in stock or available for preorder.
M3 x 16 mm machine screw, perfect for installing "D" style connectors from Neutrik, Switchcraft (EH style), Amphenol and others in rack panels, cabinets, and more. Flat heads sit flush with the flange for a clean finished look. 100 pieces per package.
Part Number081-3203
UPC848864025902
Unit of MeasurePackages
Weight0.17
Color / FinishBlack Oxide
Construction MaterialSteel
Screw Length16mm
Screw TypeFlat Head
ThreadM3
