  • Lavolta Home 5050 RGB Wi-Fi Smart 150 LED 16.4 ft. Light Strip Kit with 12 VDC 2A Power Supply
CLEARANCE Lavolta Home 5050 RGB Wi-Fi Smart 150 LED 16.4 ft. Light Strip Kit with 12 VDC 2A Power Supply
LavoltaPart # 073-087
Model: SMDA5050
Add colorful lighting to your room or home theater system with this RGB LED Wi-Fi light strip kit. Power on, change colors, change speeds, dim, or control them with your smartphone or smart speaker with the Wi-Fi RGB LED controller. The kit also includes an IR remote to keep the party going even when Wi-Fi isn't available.
  • Uses Magic Home Pro app for easy smartphone control from home or almost anywhere
  • Voice control with Alexa or Google Home devices
  • 3M peel and stick helps keep it place
We'll send you an email when Lavolta Home 5050 RGB Wi-Fi Smart 150 LED 16.4 ft. Light Strip Kit with 12 VDC 2A Power Supply is back in stock or available for preorder.
This kit includes everything you need to start a party or add colorful light to a room or home theater system. The included controller prevents you from being tied down to a remote control that only works within close range of your LED light strips. Control them anywhere when Wi-Fi or a cellular tower is available with this RGB Wi-Fi smartphone app controller. Download Magic Home Pro to your smartphone or tablet and enjoy all the available effects that an IR or RF remote does, but from almost anywhere. The kit includes an IR remote to keep the included 150 RGB LED strip within your control when Wi-Fi isn't available.
Use Alexa or Google Home app for voice control without lifting a finger. Have you ever forgotten to turn the lights off after you've left a room or went to bed? Just tell your smart speaker to turn them off without a control or waking up your smartphone.
Specifications: • Controller supply voltage: 12-24 VDC • DC Socket: 2.1 x 5.5 mm center + • Output current: 12A Max. •Included power supply output: 12 VDC @ 2A Max. • Power supply input: 100-250 VAC 50/60 Hz. • Power supply cord length: 4 ft. • Controller body dimensions: 2.09" L x 1.37" W x 0.88" H (53 x 24 x 11 mm) with 4" leads • Remote dimensions: 3.31" L x 2.04" W x 0.29' H (85 x 52 x 7.4 mm) • LEDs: RGB 5050 • Lights per meter: 30 • Strip total length: 16.4 ft.
BrandLavolta
ModelSMDA5050
Part Number073-087
UPC848864067490
Weight0.7
