  • LaVoce DF10.142LKS 1" Compression Driver
LavocePart # 293-824
Model: DF10.142LKS
LaVoce's DF10.142LKS is a high-quality compression driver offering excellent efficiency and low distortion. It is a fantastic fit for use in studio monitors, stage boxes, and sound reinforcement in small to medium rooms.
  • FEM optimized motor, phase plug, and diaphragm
  • 1,200 - 18,000 Hz frequency response
  • High-temperature polymeric diaphragm
  • 1-3/8" 18 TPI mount
Your Price: $67.00
Save $33.00 (33%)
We'll send you an email when LaVoce DF10.142LKS 1" Compression Driver is back in stock or available for preorder.
Order in the next 9 hr 42 min to ship today. Details
The LaVoce DF10.142LKS horn driver's diaphragm is crafted from a high temperature polymer. To reduce heat and distortion, the suspension has specially designed venting. The driver features an FEM optimized motor, phase plug, and diaphragm for optimal performance.
The LaVoce DF10.142LKS ferrite motor assembly effectively concentrates flux in the gap, and highest motor strength efficiency is achieved through the use of FEM (Finite Element Modeling). A voice coil manufactured with edgewound flat CCAW (Copper Clad Aluminum Wire) and wound on a fiberglass former assures great stability and thermal resistance. This driver utilizes a standard 1-3/8" 18 TPI mount.
BrandLavoce
ModelDF10.142LKS
Part Number293-824
UPC848864072838
Weight2.45
Diaphragm MaterialKapton / Polyimide
Exit Diameter1"
Mounting Type4-Bolt
Power Handling (RMS)70 Watts
Impedance8Ω
