  • LaVoce SSF082.00L 8" Paper Cone Subwoofer
LavocePart # 293-784
Model: SSF082.00L
The Lavoce SSF082.00L is the perfect candidate for a high-powered woofer or subwoofer application. Boasting 350 watts of RMS power, 29mm P-P maximum excursion and a 2” diameter CCAW voice coil, this woofer is ideal for chest thumping bass for home, studio or small PA applications.
  • 2” copper clad aluminum voice coil for exceptional power handling
  • 700 watt program power handling (350WRMS)
  • Long throw design, 29mm (1.1”) P-P excursion
  • FEM optimized motor and suspensions
  • Long lasting rubber surround
  • Heavy duty treated paper cone
Your Price: $109.00
MSRP: $163.00
Save $54.00 (33%)
5 In Stock
We'll send you an email when LaVoce SSF082.00L 8" Paper Cone Subwoofer is back in stock or available for preorder.
The Lavoce SSF082.00L is the perfect candidate for a high-powered woofer or subwoofer application. Boasting 350 watts of RMS power, 29mm P-P maximum excursion and a 2” diameter CCAW voice coil, this woofer is ideal for chest thumping bass in home, studio or small PA applications. This woofer can be front or rear mounted and uses a heavy duty resonance-free steel basket design and optimized cooling for long lasting durability. With a sensitivity of 88 dB, it won’t require the biggest amplifiers to drive efficiently.
BrandLavoce
ModelSSF082.00L
Part Number293-784
UPC848864069715
Weight10.5
Nominal Diameter8"
Power Handling (RMS)350 Watts
Power Handling (MAX)700 Watts
Frequency Response50 to 500Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)52Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)2.51mH
Mechanical Q (Qms)9.94
Electromagnetic Q (Qes)0.52
Total Q (Qts)0.49
Compliance Equivalent Volume (Vas)0.34ft³
Mechanical Compliance of Suspension (Cms)0.144mm/N
BL Product (BL)14.67T·m
Diaphragm Mass Inc. Airload (Mms)66.3g
Maximum Linear Excursion (Xmax)9mm
Surface Area of Cone (Sd)216.42cm²
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Overall Outside Diameter8.27"
Baffle Cutout Diameter7.17"
Depth4.49"
Sealed Volume0.35ft³
Sealed F360.2Hz
Vented Volume0.7ft³
Vented F342.5Hz
