  • LaVoce HD1403 1.4" Cast Aluminum Constant Directivity Horn 80 x 60 4-Bolt
LavocePart # 293-744
Model: HD1403
1 Question, 1 Answer or
With an 80 x 60 degree dispersion pattern, LaVoce's HD1403 cast aluminum horn is perfect for filling a wide area with sound while controlling unwanted reflections. The 1.4" throat and low 900 Hz cutoff frequency makes this horn compatible with many of your favorite compression drivers.
  • 80 x 60 degree dispersion pattern with excellent directivity control
  • Aluminum construction to ensure a solid mount and excellent heat dissipation
  • FEM optimized for constant directivity with extremely even coverage
  • Low 900 Hz cutoff frequency for use with many popular 1.4" exit compression drivers
Your Price: $69.00
MSRP: $103.00
Save $34.00 (33%)
Only 1 In Stock
We'll send you an email when LaVoce HD1403 1.4" Cast Aluminum Constant Directivity Horn 80 x 60 4-Bolt is back in stock or available for preorder.
Order in the next 15 hr 54 min to ship today. Details
LaVoce's HD1403 1.4" constant directivity horn is a great choice when you need controlled dispersion midrange and high frequency output. With a rugged aluminum construction this horn will support the weight of the largest compression drivers while actually wicking away heat to help lower power compression. The controlled 80° x 60° dispersion pattern will deliver the output right where you need it while minimizing unwanted reflections. This horn is a great choice for use with any of your favorite 1.4" exit compression drivers.
Specifications: • Throat diameter: 1.4" • Driver mounting: 4-bolt • Nominal coverage: 80°H x 60° V • Cutoff frequency: 900 Hz • Dimensions: 10.6" H x 11" W x 4.5" D • Cutout dimensions: 8.8" H x 9.5" W.
BrandLavoce
ModelHD1403
Part Number293-744
UPC848864061467
Weight4.1
ConstructionAluminum
Entry / Throat Diameter1.4"
Mounting Type4-Bolt
