  • LaVoce DN10.172K Neodymium 1" Polyimide Compression Driver 4-Bolt
LavocePart # 293-776
Model: DN10.172K
Lavoce’s DN10.172K 1” neodymium compression driver has been engineered for smooth response, low distortion, and high SPL output. With a 1.7” edgewound voice coil, damped polyimide diaphragm/surround assembly, and extremely powerful neodymium magnet this driver is capable of remarkably smooth response with minimal power compression. The DN10.172K is perfect for any high output design that requires flat response, high power handling, and extreme output capability.
  • FEM optimized neodymium motor, phase plug, and diaphragm to deliver remarkably accurate response
  • 1.7” edgewound CCA voice coil on high temp Kapton former for low mass with maximum motor force
  • Next generation compression driver delivers natural sound and high output capability
  • Damped polyimide diaphragm and surround provides smooth and natural high frequency response
  • Standard 4-bolt mount for use on many popular 1” throat horns and waveguides
Your Price: $135.00
Save $66.00 (33%)
Only 1 In Stock More due on 10/28/2026
We'll send you an email when LaVoce DN10.172K Neodymium 1" Polyimide Compression Driver 4-Bolt is back in stock or available for preorder.
Order in the next 12 hr 31 min to ship today. Details
The DN10.172K 1” high frequency neodymium compression driver from Lavoce’s Next Generation line offers lower distortion, smoother response, and lower power compression than their previous designs. With a naturally damped high temperature polyimide diaphragm and surround, the DN10.172K produces extremely flat response all the way up to 20,000 Hz for a natural and detailed sound. To minimize mass, the voice coil uses a heat resistant Kapton former wrapped with edgewound copper coated aluminum wire which allows this driver to deliver 110 dB sensitivity. The high energy neodymium motor has been optimized to dissipate unwanted heat which helps control power compression ensuring that output levels are consistent, even after being pushed to the limit for extended periods of time. Thanks to the smooth response and impressive output capability, the DN10.172K is capable of providing dynamic performance to anything from premium home audio systems to no-compromise professional designs capable of extreme sound pressure levels.
Specifications: • Power handling: 55 watts RMS (110 watts program power) • VCdia: 1.7" • Impedance: 8 ohms • Recommended crossover: 1,500 Hz @ 12dB/octave high pass • Frequency response: 1,200-20,000 Hz • SPL: 110 dB 2.83V/1m • Dimensions: 3.3" diameter x 1.5" depth • Net weight: 2 lbs.
BrandLavoce
ModelDN10.172K
Part Number293-776
UPC848864068213
Weight2.1
Diaphragm MaterialKapton / Polyimide
Exit Diameter1"
Mounting Type4-Bolt
Power Handling (RMS)55 Watts
Impedance8Ω
