  • LaVoce DN10.17 1" Neodymium Compression Driver 8 Ohm
LavocePart # 293-736
Model: DN10.17
LaVoce's DN10.17 is a high-quality compression driver offering excellent efficiency and low distortion. It is a fantastic fit for use in studio monitors, stage boxes, and sound reinforcement in small to medium rooms.
  • FEM optimized motor, phase plug, and diaphragm
  • 1,200 - 18,000 Hz frequency response
  • High-temperature polymeric diaphragm
  • 4-Bolt mounting
We'll send you an email when LaVoce DN10.17 1" Neodymium Compression Driver 8 Ohm is back in stock or available for preorder.
The LaVoce DN10.17 horn driver's diaphragm is crafted from a high temperature polymer. To reduce heat and distortion, the suspension has specially designed venting. The driver features an FEM optimized motor, phase plug, and diaphragm for optimal performance.
The LaVoce DN10.17 neodymium motor assembly effectively concentrates flux in the gap, and highest motor strength efficiency is achieved through the use of FEM (Finite Element Modeling). A voice coil manufactured with edgewound flat CCAW (Copper Clad Aluminum Wire) and wound on a fiberglass former assures great stability and thermal resistance. This driver utilizes a standard 4-bolt mounting method.
BrandLavoce
ModelDN10.17
Part Number293-736
UPC848864057583
Weight2.1
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type4-Bolt
Power Handling (RMS)55 Watts
