  • LaVoce DN10.142 Neodymium 1" Polymer Compression Driver 2-Bolt
LavocePart # 293-772
Model: DN10.142
The compact DN10.142 1” neodymium compression driver from Lavoce has been engineered for smooth response, low distortion, and high SPL output. With a 1.4” edgewound voice coil, damped polymer diaphragm/surround assembly, and high energy neodymium magnet this driver is capable of remarkably smooth response with minimal power compression. The DN10.142 is ideal for use in any system designed for dynamic high output capability and natural response.
  • FEM optimized motor, phase plug, and diaphragm to deliver remarkably accurate response
  • 1.4” edgewound CCA voice coil on high temp Kapton former for low mass with maximum motor force
  • Next generation compression driver delivers natural sound and high output capability
  • Damped polymer diaphragm and surround provides smooth and natural high frequency response
  • Standard 2-bolt mount for use on many popular 1” throat horns and waveguides
Your Price: $79.00
MSRP: $118.00
Save $39.00 (33%)
Only 1 In Stock
We'll send you an email when LaVoce DN10.142 Neodymium 1" Polymer Compression Driver 2-Bolt is back in stock or available for preorder.
Order in the next 0 hr 25 min to ship today. Details
Lavoce’s DN10.142 1” neodymium high frequency compression driver packs incredible output potential into a compact package. Don’t let the small size fool you, Lavoce developed this next generation driver to provide no-compromise performance with low distortion and flat response. A naturally damped high temperature polymer diaphragm and surround ensures that the DN10.142 produces smooth response. The high temperature Kapton former is wound with an edgewound copper coated aluminum voice coil to minimize power compression while maximizing motor force for high efficiency. The powerful neodymium motor keeps size and weight as low as possible without sacrificing efficiency or power handling. Thanks to the small size, this driver is perfect for high performance compact 2-way designs and high output line arrays.
Specifications: • Power handling: 25 watts RMS (50 watts program power) • VCdia: 1.4" • Impedance: 8 ohms • Recommended crossover: 1,200 Hz @ 12dB/octave high pass • Frequency response: 1,000-18,000 Hz • SPL: 107 dB 2.83V/1m • Dimensions: 2.4" diameter x 1.3" depth • Net weight: 0.66 lbs.
BrandLavoce
ModelDN10.142
Part Number293-772
UPC848864068190
Weight0.8
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type2-Bolt
Power Handling (RMS)25 Watts
