  • Lavolta LED Lighting Strip to Controller Solderless Splice Cable 150mm 5 Pcs.
CLEARANCE Lavolta LED Lighting Strip to Controller Solderless Splice Cable 150mm 5 Pcs.
LavoltaPart # 073-0104
Use this Lavolta 150 mm (5.91") male-to-male 4-pin solderless splice cable to connect two LED lighting strips together, or use it as an extension cable between an LED lighting strip and an LED controller.
  • Quickly, safely connect two LED strips together
  • Acts as a 5.91" extension cable
  • Polarity marked
  • Sold in bags of 5
CLEARANCE $2.50
Save $6.49 (72%)
85 In Stock
We'll send you an email when Lavolta LED Lighting Strip to Controller Solderless Splice Cable 150mm 5 Pcs. is back in stock or available for preorder.
Order in the next 8 hr 42 min to ship today. Details
Connect two LED lighting strips together with this 5.91" (150 mm) four-pin, male-to-male extension splice cable from Lavolta. Additionally, use this cable as an extension between an LED controller and the LED lighting strip.
Pin polarity is marked on each connector for quick, correct connection. Hard to navigate corners and angles are made easy to work with due to the cables pliable construction. Each connector head features a molded strain relief. Sold in bags of 5.
Note: When directly connecting multiple LED strips together using this 4-pin male-to-male connector, it is important not to exceed a total series length of 33 feet. Doing so can damage some controllers, power supplies, and cause resistors within the LED lighting strip to overheat, creating a color difference between strips.
BrandLavolta
Part Number073-0104
UPC848864015545
Weight0.1
