  • Kicker DSC6930 DS Series 6" x 9" 3-Way Speaker Pair
CLEARANCE Kicker DSC6930 DS Series 6" x 9" 3-Way Speaker Pair
KickerPart # 267-6874
Model: 43DSC69304
Replace those tired, worn-out, underperforming, stock speakers in your car, truck, or SUV with Kicker D Series speakers. The DSC6930 6" x 9" three-way speaker gives you the midbass thump and clean, airy highs missing from factory speakers.
  • Easy to install and instantly improves your vehicle's sound
  • High 92 dB sensitivity
  • 50 mm midrange for more output
  • Sold in pairs, includes grills and mounting hardware
We'll send you an email when Kicker DSC6930 DS Series 6" x 9" 3-Way Speaker Pair is back in stock or available for preorder.
For an easy-to-install, drop-in factory speaker upgrade, the Kicker D Series three-way speakers provide the clear midrange and crystal clear highs that ultimately define a great-sounding audio system—all while fitting neatly within your budget, and in your door.
The DSC6930 6" x 9" triaxial speaker's woofer uses a high-sensitivity motor, stiff polypropylene cone, and acoustic foam surrounds not found in stock automotive speakers. Not only does this give you the increased output you are looking for with factory head units, but it can handle the power from add-on amplifiers. The overall thin profile of the DSC6930 keeps it from obstructing car window mechanisms.
A coaxially mounted 13 mm PEI (polyether imide) tweeter supplies outstanding definition, with minimal protrusion. For even more output, the DSC6930 includes a 50 mm midrange driver. Sold in pairs. Includes grills and mounting hardware.
Specifications: • Power handling: 90 watts RMS/360 watts peak • Impedance: 4 ohms • Frequency response: 30-20,000 Hz • SPL: 92 dB • Overall diameter: 6" x 9" • Cutout diameter: 5-5/8" x 8-7/16" • Mounting depth: 3-3/16".
BrandKicker
Model43DSC69304
Part Number267-6874
UPC713034077701
Unit of MeasurePairs
Weight8.1
Speaker Size6"
Speaker Type3-Way
Power Handling (RMS)90 Watts
