CLEARANCE Kicker CompRT-6.75 6.75" DVC Subwoofer 4 Ohm
Kicker's CompRT Series subwoofers feature all of the quality and performance you have come to know from Kicker, in a thinner, shallow mount package.
- A ribbed, UV-treated surround with white double stitching binds the suspension to a thick polypropylene cone for excellent reliability
- The basket uses high-quality stamped steel for outstanding stability under extreme stress
- All-weather rated for the most extreme environments
- Perimeter venting allows air to move freely around the motor for excellent heat management
- Forced-Air Cooling helps keep the CompRT series run 20% cooler than before
- The spring-loaded, satin nickel terminals accept a wide range of speaker wires
- Less than 3" of mounting depth
We'll send you an email when Kicker CompRT-6.75 6.75" DVC Subwoofer 4 Ohm is back in stock or available for preorder.
