CLEARANCE Kicker Comp-12 12" Subwoofer 4 Ohm
Kicker's C12 12" 4 ohm Comp Series subwoofer features elite Kicker construction and is built for maximum bang-for-your-buck!
- A ribbed, UV-treated surround with white double stitching binds the suspension to a thick polypropylene cone for excellent reliability
- The basket uses high-quality stamped steel for outstanding stability under extreme stress
- The bumped back plate allows the high-temp voice coil to move even more, so you get deeper bass without distortion
- Perimeter venting allows air to move freely around the motor for excellent heat management
- A stiff injection-molded cone with 360-degree back bracing keeps the bass smooth and loud all day long
- The spring-loaded, satin nickel terminals accept a wide range of speaker wires
We'll send you an email when Kicker Comp-12 12" Subwoofer 4 Ohm is back in stock or available for preorder.
