  • KAS2230MLC Splash Waterproof Sound Projector Speaker 70V
CLEARANCE KAS2230MLC Splash Waterproof Sound Projector Speaker 70V
Factory BuyoutsPart # 299-4289
Model: KAS2230MLC
The KAS2230DLC Splash Waterproof Sound Projector Speaker is an outdoor surface mount speaker designed to take a beating by the elements.
  • IEC529, IPX6 rated for outdoor longevity
  • 2.5W, 5W, 10W, 15W, 20W and 8 ohm tap settings for installation versatility
  • High SPL for covering large areas
We'll send you an email when KAS2230MLC Splash Waterproof Sound Projector Speaker 70V is back in stock or available for preorder.
The KAS2230MLC Splash Waterproof Sound Projector Speaker is an outdoor surface mount speaker designed to take a beating by the elements. It features an all ABS plastic housing that is UV protected, a powder-coated metal mounting bracket and stainless hardware.
It's 6" full-range speaker is a great choice for hallways, corridors or filling large areas with sound coverage. A built-in 70-volt transformer provides five different tap settings, as well as an 8 ohm bypass. The design helps direct the sound where you want it to go and boosts overall efficiency, allowing you do aim the sound to whichever area you need.
  • 7.25"W x 12.25"D (including mounting bracket)
  • 70.7V tap settings: 5W, 10W, 15W, 20W, 8 ohm
  • Frequency response: 80 to 20,000 Hz
  • SPL: 92dB, 107dB Max
  • IEC529, IPX5 rated
BrandCoast Buyouts
ModelKAS2230MLC
Part Number299-4289
UPC848864081359
Weight7.85
