  • KAS2120MLC 6" Splash Waterproof Sound Projection Speaker
BUYOUT KAS2120MLC 6" Splash Waterproof Sound Projection Speaker
Factory Buyouts
Part #299-4284
Factory Buyouts
Part #299-4284
Model: KAS2120MLC
The KAS2230MLC 6" Splash Waterproof Sound Projection Speaker is an outdoor surface mount speaker designed to take a beating by the elements.
  • IEC529, IPX6 rated for outdoor longevity
  • 2.5W, 5W, 10W, 15W, 20W and 8 ohm tap settings for installation versatility
  • High SPL for covering large areas
BUYOUT $29.88
MSRP: $79.99
Save $50.11 (63%)
Quantity:Qty: 1-4 $29.88/ea
Quantity:Qty: 5-9 $27.88/ea
Quantity:Qty: 10+$25.88/ea
Order in the next 3 hr 51 min to ship today. Details
42In Stock
The KAS2230MLC 6" Splash Waterproof Sound Projection Speaker is an outdoor surface mount speaker designed to take a beating by the elements. It features an all ABS plastic housing that is UV protected, a powder-coated metal mounting bracket and stainless hardware.
A built-in 70-volt transformer provides five different tap settings, as well as an 8 ohm bypass. The design helps direct the sound where you want it to go and boosts overall efficiency, allowing you do aim the sound to whichever area you need.
  • 7.25"W x 12.25"D (including mounting bracket)
  • 70.7V tap settings: 5W, 10W, 15W, 20W, 8 ohm
  • Frequency response: 100 to 20,000 Hz
  • SPL: 93dB, 107dB Max
  • IEC529, IPX5 rated
BrandFactory Buyouts
ModelKAS2120MLC
Part Number299-4284
UPC848864073873
Weight6.75
