  • KAR3154 8" Aluminum Speaker Enclosure with Mounting Bracket
CLEARANCE KAR3154 8" Aluminum Speaker Enclosure with Mounting Bracket
Read 1 Review or
Factory Buyouts
Part #299-4282
Factory Buyouts
Part #299-4282
Model: KAR3154
Read 1 Review or
The KAR3154 8" Aluminum Speaker Enclosure with Mounting Bracket is a great choice for protecting the rear of your 8" ceiling speaker from moisture, blown-in insulation or unwanted critters.
  • Spun aluminum housing resists corrosion
  • Protects the rear of speakers from unwanted weather, moisture or insulation
  • Sized to fit most standard 8" public address ceiling speakers
CLEARANCE $5.88
MSRP: $19.99
Save $14.11 (71%)
Quantity:Qty: 1-9 $5.88/ea
Quantity:Qty: 10-19 $5.48/ea
Quantity:Qty: 20+$4.88/ea
6In Stock
The KAR3154 8" Aluminum Speaker Enclosure with Mounting Bracket is a great choice for protecting the rear of your 8" ceiling speaker from moisture, blown-in insulation or unwanted critters. The spun-aluminum housing includes two weather-resistant grommets that will accept wire diameters up to 1/4" and a steel mounting bracket.
The enclosure measures 8-3/8" across the outer flange and 7-5/8" inside, with a depth of 4-5/8". Exterior depth is 6", including grommets.
BrandFactory Buyouts
ModelKAR3154
Part Number299-4282
UPC848864073866
Weight1.4
