  • K&M 24110 Heavy-Duty Speaker Wall Mount - Up to 22 Tilt
CLEARANCE K&M 24110 Heavy-Duty Speaker Wall Mount - Up to 22 Tilt
K&MPart # 242-7736
Model: 24110
K&M's 24110 heavy-duty tilting speaker mount is constructed of solid steel bar stock, making it one of the most robust wall mounting choices available today. A patented ring lock mechanism provides guaranteed effective clamping of the speaker in any position.
  • Patented ring lock system secures your speaker
  • Tilt adjustable from 0° to 22°
  • Massive 110 lb. capacity
  • Designed and manufactured in Germany
We'll send you an email when K&M 24110 Heavy-Duty Speaker Wall Mount - Up to 22 Tilt is back in stock or available for preorder.
Time-honored German quality and pride go into every K&M product, and the 24110 wall mount is certainly no exception. Solid steel construction along with K&M's relentless quality standards ensure this mount will do the job you need it to do, no compromises or excuses. The mounting post is a standard 1-3/8" diameter, and is fitted with K&M's patented expanding mandrel system, which allows you to positively lock your speaker to the mount. This action also helps to isolate the speaker from the mount and wall, reducing resonance introduced by sympathetic vibrations. The angle of tilt is adjustable from 0° to 22°, in eleven steps. The clearance from the wall to the post is 16.54", which is plenty to accommodate most speakers, with room to spare. The weight capacity is an impressive 110 pounds, so even the most punishing speakers can be mounted. With every product backed by K&M's 5 year warranty (and most replacement parts guaranteed to be available for 10 years), you know K&M products are built to perform for the long haul!
BrandK&M
Model24110
Part Number242-7736
Weight6.55
