  • Jensen JT-10KB-D Premium Line Bridging Step Down Transformer 4:1
Jensen TransformersPart # 246-0109
Model: JT-10KB-D
The JT-10KB-D line output transformer from Jensen is typically used for "balanced bridging" inputs, or Pro to Consumer level conversion. You'll find this and other Jensen transformers in many top-of-the-line "boutique" brands for one simple reason: they're the best.
Your Price: $119.99
We'll send you an email when Jensen JT-10KB-D Premium Line Bridging Step Down Transformer 4:1 is back in stock or available for preorder.
Order in the next 0 hr 8 min to ship today. Details
If you're building your own or upgrading an existing Pro to Consumer signal level converter, the JT-10KB-D from Jensen is the best transformer for the job. Full-range frequency response is delivered with surgical precision, with multiple layers of protection from distortion, hum, buzz, and RF interference.
Jensen's MuMETAL® shielding is known the world over for its protection against the intrusion of magnetic field or RF interference. Jensen has also designed and implemented multiple Faraday shields to further safeguard your signal from unwanted noise that can ruin your live performance or studio recording. Without getting deep into a bunch of scientific mumbo-jumbo, let's just say Jensen is the best you can get, and that's why the top names in music, recording, and broadcasting won't use anything else. Go with what the pros know. Jensen. The world's finest transformers.
See the Project Design Schematics under Manuals/Resources for application schematics.
Specifications: Impedance ratio: 40k:2.4k • Turns ratio: 4:1 • Max input (@ 20 Hz): +21 dBu • THD (@ 20 Hz): 0.015% • Dimensions: 1.13” diameter x 1.03” • Wire leads: 30 AWG UL style color coded, 8” minimum length.
BrandJensen Transformers
ModelJT-10KB-D
Part Number246-0109
UPC848864028576
Weight0.18
