  • Jensen Iso-Max VRD-1FF 75 Ohm Inline Digital CATV Isolator Hum Eliminator
Jensen TransformersPart # 246-0121
Model: VRD-1FF
Jensen's Iso-Max isolators use the world's best transformers to solve a problem common to pro audio, home theater, car audio, and audiophiles alike: the dreaded HUM. The VRD-1FF is a video isolator designed specifically for 75 ohm CATV lines, analog or digital (not satellite-friendly). Connect it between your source and destination to eliminate hum bars without degrading picture quality.
  • Hum / ground loop eliminator designed for CATV systems
  • Built using the finest transformers money can buy: Jensen
  • Passive design means no power or batteries needed
  • Rugged construction for long service life
Your Price: $74.99
MSRP: $82.49
Save $7.50 (9%)
We'll send you an email when Jensen Iso-Max VRD-1FF 75 Ohm Inline Digital CATV Isolator Hum Eliminator is back in stock or available for preorder.
Order in the next 0 hr 57 min to ship today. Details
The VRD-1FF was engineered for use with composite video systems, and is used to remove ground-loop hum and "hum bars" from signals in virtually any application. With high quality F cables, connect the VRD-1FF between your source device and your TV panel or monitor. Also great for CCTV systems where long camera runs are prone to DC or RF interference.
We've all been there before. You spend hard-earned money and hours of your time selecting just the right components and putting together a great system. You get everything hooked up, plug it in and fire it up and BAM! That dastardly hum rears its ugly head. It's not just an audiophile issue. It happens anywhere you might want to install high quality sound or video. Home theater, mobile audio, pro audio and commercial sound systems can all be plagued by this most vile and wretched affliction.
Lucky for you, Jensen has introduced solutions for virtually any type of setup in which you might encounter this pernicious foe. Using world-renowned Jensen transformers, the Iso-Max line of products kills the hum without killing your sound quality. Simply insert the Iso-Max unit into your signal path, and voilà! Hum is out, and clean luscious sound is all that's left. Enjoy!
Specifications: Bandwidth: 2 - 1300 MHz • Connectors: F male • Insertion loss: 0.19 / 0.01 dB (@ 5 MHz / 50 MHz) • VSWR: < 1.2 • Dimensions: 2.52" x 0.66".
BrandJensen Transformers
ModelVRD-1FF
Part Number246-0121
UPC676101041473
Weight0.1
