  • Jensen Iso-Max DIN-LI Single Channel DIN Rail Line Input Isolator
Jensen TransformersPart # 246-0132
Model: DIN-LI
Jensen's Iso-Max isolators use the world's best transformers to solve problems common to pro audio, home theater, car audio, and audiophiles alike. The DIN-LI is a single channel line input isolator which mounts conveniently in NEMA enclosures with standard DIN rail.
  • Hum / ground loop eliminator designed for system integrators
  • Built using the finest transformers money can buy: Jensen
  • Passive design means no power or batteries needed
  • DIN rail mount & screw terminal termination
Your Price: $179.99
MSRP: $197.99
Save $18.00 (9%)
We'll send you an email when Jensen Iso-Max DIN-LI Single Channel DIN Rail Line Input Isolator is back in stock or available for preorder.
Order in the next 1 hr 10 min to ship today. Details
Use the DIN-LI to remove ground-loop hum from balanced or unbalanced mono signals. DIN rail mounting and screw terminals make it quick and easy to install, and since it's from Jensen, you know you'll be able to rely on years of outstanding quality and performance.
We've all been there before. You spend hard-earned money and hours of your time selecting just the right components and putting together a great sound system. You get everything hooked up, plug it in and fire it up and BAM! That dastardly hum rears its ugly head. It's not just an audiophile issue. It happens anywhere you might want to install high quality sound. Home theater, mobile audio, pro audio and commercial sound systems can all be plagued by this most vile and wretched affliction.
Lucky for you, Jensen has introduced solutions for virtually any type of setup in which you might encounter this pernicious foe. Using world-renowned Jensen transformers, the Iso-Max line of products kills the hum without killing your sound quality. Simply insert the Iso-Max unit into your signal path, and voilà! Hum is out, and clean luscious sound is all that's left. Enjoy!
Specifications: Frequency response: < 10 - 50,000 Hz • Connectors: screw terminals • Max input: +19 dBu (@20 Hz) • CMRR noise rejection: 95 dB @ 60 Hz • Dimensions: 3.85" x 1.42" x 2.3".
BrandJensen Transformers
ModelDIN-LI
Part Number246-0132
UPC676101041732
Weight0.4
