  • Jantzen Audio 1.80mH 15 AWG Litz Wire Air Core Inductor
Jantzen AudioPart # 255-530
Model: 000-L-0180
Constructed of 7 strands of 0.5 mm ETP copper, Jantzen Audio's 15-gauge wax impregnated Litz wire inductors offer lower skin and proximity effect than comparable sized solid wire inductors for improved high frequency dynamics and clearer sound. The wax impregnation keeps the windings in place and eliminates distortion and microphonic effect.
  • 15-gauge (7 twisted 0.5 mm wires) conductor for low resistance and high power
  • Wax coated creates very dense and inert structure to avoid mechanical coloration
  • Reduced skin effect and saturation compared to conventional wire-based inductors
  • Tinned wire ends for easy connection and soldering
Your Price: $40.21
MSRP: $52.99
Save $12.78 (24%)
Out of Stock
We'll send you an email when Jantzen Audio 1.80mH 15 AWG Litz Wire Air Core Inductor is back in stock or available for preorder.
Special Order Items ships in 40-60 days
Jantzen Audio's Litz Wire Wax Coil inductors are a true innovation in audio grade inductors. Constructed of 7 strands of 0.5 mm ETP copper, these inductors produce lower skin and proximity effect than equivalent sized coils wound using solid conductors. To hold everything in place, each of these inductors is impregnated with Jantzen Audio's proprietary polymolecular paraffin wax eliminating the possibility of mechanical distortion and any microphonic effects.
Jantzen Audio's part #: 000-L-0180
Specifications: • Inductance: 1.80 mH • Wire gauge: 15 AWG (7 x 0.5 mm conductors) • DC Resistance: 0.49 ohms • Power handling: 400 watts RMS • Tolerance: ± 3.0% • Dimensions: 30 mm H x 70 mm Dia.
BrandJantzen Audio
Model000-L-0180
Part Number255-530
UPC848864052489
Weight1.1
DCR0.49Ω
Inductance1.8mH
Inductor TypeAir Core
Wire Gauge15
