  • Jantzen Audio 0.22mH 16 AWG Copper Foil Wax Coil Crossover Coil
CLEARANCE Jantzen Audio 0.22mH 16 AWG Copper Foil Wax Coil Crossover Coil
Jantzen AudioPart # 255-504
Model: 000-8540
The 99.9998% pure copper foil used in Jantzen Audio's Cross Coil Series inductors is the basis for the Wax Coil. Insulated with 60 micron special-quality paper, the foil is precision-wound tightly and then impregnated with Jantzen Audio's proprietary polymolecular paraffin wax.
  • Almost perfectly pure copper foil
  • Flat cross section increases surface area, improves skin effect characteristics
  • Premium paper insulation and proprietary wax for superior results
  • Very dense and inert structure avoids mechanical coloration
  • Superb product consistency for more accurate filter performance
  • High power handling and extreme precision
  • Amazing musicality and soundstage
We'll send you an email when Jantzen Audio 0.22mH 16 AWG Copper Foil Wax Coil Crossover Coil is back in stock or available for preorder.
The 99.9998% pure copper foil used in Jantzen Audio's Cross Coil Series inductors is the basis for the Wax Coil. Insulated with 60 micron special-quality paper, the foil is precision-wound tightly and impregnated with Jantzen Audio's proprietary polymolecular paraffin wax. This meticulous process eliminates air bubbles that can occur from the use of conventional materials and methods.
Upon curing, the coil becomes completely dense, solid, and incredibly hard, which eliminates unwanted mechanical resonation and guarantees product consistency. After manufacture each coil is tested individually with an Audiomatica CLIO electro-acoustic measurement system. Jantzen Audio p/n 000-8540.
Specifications: • Tolerance: ± 2.0% • Inductance: 0.22 mH • Wire gauge: 16 AWG • DC resistance: 0.148 ohms • Dimensions H. x dia. (mm): 49 x 27 • Power handling: 350 watts RMS for 16 gauge, 500 watts RMS for 14 gauge and 650 watts RMS for 12 gauge.
BrandJantzen Audio
Model000-8540
Part Number255-504
UPC844632095269
Weight0.34
DCR0.148Ω
Inductance0.22mH
Inductor TypeCopper Foil
Wire Gauge16
