  • Jantzen Audio 0.11mH 16 AWG Cross Coil Pure Copper Inductor
CLEARANCE Jantzen Audio 0.11mH 16 AWG Cross Coil Pure Copper Inductor
Jantzen AudioPart # 255-604
Model: 000-7622
The Jantzen Audio Cross Coil is a pure copper foil audio inductor developed in cooperation with Audiotechnology in Denmark. It’s engineered to offer improved power handling and dynamic headroom compared to traditional wire-based inductors.
  • High-performance foil inductor offering improved power handling and dynamic headroom
  • Constructed using pure copper foil for better electron travel and lower distortion
  • Designed to minimize power distortion by reducing “surface squeeze” effects
  • Coil wrapped in clear shrink foil to protect the outer foil layer
  • Inductance tolerance of ±2%
  • DCR (coil resistance) tolerance of ±5%
We'll send you an email when Jantzen Audio 0.11mH 16 AWG Cross Coil Pure Copper Inductor is back in stock or available for preorder.
Jantzen Audio Cross Coil Pure Copper Inductors
Product Features
The Cross Coil was developed in cooperation with Mr. Per Skaaning from Audio Technology in Denmark.
It is a high-performance foil inductor offering improved power handling and dynamic head room.
Using pure copper foil, we have insured a better surface for electron travel, a better distortion reduction, a higher power handling and improved dynamic headroom, compared to wire-based inductors.
The coil is wrapped in clear shrink foil to protect the outer layer of foil and to help maintain the integrity of the windings.
Jantzen knows that with rising frequency, the electrons will move towards the surface. This Phenomenon is known as power distortion. Therefore, we need as large a surface as we can get, to prevent the electrons from getting “squeezed" on their path to the surface.
Technical Data
  • Made from ETP (Electrolytic-Tough-Pitch) copper foil
  • The copper foil is C11000 / IACS certified
  • Inductance tolerance: ± 2%
  • DCR (coil resistance) tolerance: ± 5%
  • Insulation: Polypropylene shrink foil (clear)
Electrical Properties
  • Inductance: 0.1100 mH
  • DCR: 0.1000 Ω
  • AWG: 16
Dimensions
  • Inner ø: 10 mm
  • Outer ø: 41 mm
  • Height: 27 mm
BrandJantzen Audio
Model000-7622
Part Number255-604
UPC844632023231
Weight0.24
DCR0.11Ω
Inductance0.11mH
Inductor TypeCopper Foil
Wire Gauge16
