  • JBL SP8II 8" 2-Way In-Wall Speaker Pair with Swiveling Tweeter and EOS Waveguide
CLEARANCE JBL SP8II 8" 2-Way In-Wall Speaker Pair with Swiveling Tweeter and EOS Waveguide
JBL ProfessionalPart # 322-306
Model: SP8II
A pair of JBL SP8II in-wall loudspeakers offers any home true JBL-quality sound without taking up valuable floor or shelf space. Movies sound more enveloping within your home theater, and your favorite music comes alive throughout the house.
  • Accurate highs and extended lows inspired by JBL Professional monitor speakers
  • Save space by mounting these easy to install speakers in your wall
  • EOS waveguide technology makes your whole room the perfect listening position
  • Blend the speakers into your living space with paintable grills and frames
  • Sold as a pair
We'll send you an email when JBL SP8II 8" 2-Way In-Wall Speaker Pair with Swiveling Tweeter and EOS Waveguide is back in stock or available for preorder.
The SP8II’s 8" titanium-laminate low-frequency woofer delivers exceptional bass, while the swivel-mounted, titanium-laminate tweeter produces accurate, clear high-frequency output. Proprietary Elliptical Oblate Spheroidal (EOS) waveguide technology and a maximum power handling of 100 watts ensure that each SP6II distributes sound evenly and smoothly throughout your listening area. Shallow mounting depths increase your installation options. And the JBL SP6II’s paintable frame and grill let it blend into any room décor.
8" Titanium-Laminate Cone Woofer for Enhanced Bass Response
Realistic reproduction of music requires clean, undistorted low frequencies. JBL SP8II in-wall loudspeakers feature 8" titanium-laminate cone woofers with rubber surrounds that produce deep, powerful bass with low distortion. The result is enveloping, satisfying audio reproduction from the bottom up.
Detailed High-Frequency Sound Reproduction
The SP8II’s thin but rigid 1" pure titanium-laminate tweeter delivers accurate, clear high-frequency response, even at elevated volume levels. The tweeter’s swivel mount means that high frequencies can be directed exactly where you want them for the best available soundstage.
Elliptical Oblate Spheroidal (EOS) Waveguide for "Sit-Anywhere" Sound
With proprietary JBL Elliptical Oblate Spheroidal (EOS) waveguide technology, your whole room becomes a perfect listening position. Originally designed for JBL Professional LSR studio monitors, the SP5II in-wall loudspeaker’s EOS waveguide distributes sound evenly throughout your playback area.
Low Profile and Easy Installation
With a mounting depth of just 4" and a weight of only 7.8 pounds, the lightweight, space-saving JBL SP6II loudspeakers offer maximum installation flexibility. A cutting template and integrated dog-ear brackets accommodate retrofit applications, while rough-in frames are available for new construction.
Paintable Grill and Frame
JBL SP8II in-wall loudspeakers offer outstanding performance, but that doesn’t mean that they have to stand out in a room. You can paint the frames and grills so that the loudspeakers match your wall décor. You’ll hardly notice your SP8IIs – until you turn them on.
Specifications: • Power handling: 100 watts max • 8 ohm impedance • Frequency response: 30-20,000 Hz (-10dB) • Sensitivity: 89 dB (2.83V @ 1m) • Mounting depth: 4" • Cutout dimensions: 8-7/8" W x 11-13/16" H • Overall dimensions: 10-1/8" W x 13-1/8" H.
BrandJBL
ModelSP8II
Part Number322-306
UPC050036922463
Unit of MeasurePairs
Weight14
Configuration2-way
Woofer Diameter8"
Special FeaturesSwiveling Tweeter
