  • JBL Control 85M Compact 2-Way 5-1/4" Mushroom-Style Landscape Speaker 70V / 100V / 8 Ohm
JBL ProfessionalPart # 246-8477
Model: Control 85M
The Control 85M by JBL is a highly weather-resistant 2-way landscape speaker which provides 360° coverage for outdoor areas. The Control 85M is ideal for hotels, casinos, pool areas, malls, theme parks, sports facilities, resorts, restaurants, hospitality and leisure venues, and anywhere high quality music and/or paging is required in an outside setting.
  • Finally - a tough outdoor speaker with outstanding fidelity
  • 70V/100V or 8 ohm compatible for maximum versatility
  • Rugged polyethylene weather-resistant enclosure
  • Certified IP55, UL94V0, UL1480, UL76 and more
Your Price: $295.00
We'll send you an email when JBL Control 85M Compact 2-Way 5-1/4" Mushroom-Style Landscape Speaker 70V / 100V / 8 Ohm is back in stock or available for preorder.
Order in the next 5 hr 39 min to ship today. Details
Designed for outdoor applications, the Control 80 Series Landscape speakers from JBL provide excellent full-range sound quality and 360 degree coverage. Its compact size allows the speaker to blend into landscaping and shrubbery, while a tough polyethylene enclosure resists abuse from lawn care equipment and the elements, and the enclosure color extends throughout the material so the speaker will maintain color even when scraped or scratched.
The two-piece enclosure is designed to opened with a twist for wiring and installation, then to close securely. The bottom base section can be pre-installed, then wired to the top section of the enclosure at your convenience. When assembled, the base section becomes a fully isolated chamber, keeping the speaker and transformer protected from moisture. Multiple locations on the bottom and sides are provided for mounting the exterior gland nut, and a second gland nut is positioned between the base and the top speaker section, effectively battening down the hatches against inclement environmental conditions. The included gland nuts maintain a watertight seal when used with round jacketed cable with a diameter between 0.16" and 0.35" (4 - 9 mm).
All external hardware is stainless steel, and the powder-coated stainless steel speaker grille resists rust. Three extended tabs are molded into the base section so the Control 85M can be secured to the ground using stakes (not included), or the anchoring method of your choosing.
Specifications: • Frequency range (-10 dB): 55 - 18,000 Hz • Frequency response (±3 dB): 65 - 16,000 Hz • Power rating: 160W continuous program (2 hrs); 80W (320W peak) continuous pink noise (2 hrs); 45W (180W peak) continuous pink noise (100 hrs) • Maximum input voltage: 23.3 V • Nominal sensitivity: 86 dB • Coverage angle: 360° horizontal, 160° vertical (primary listening 10° to 50° up from ground plane) • Directivity (Q): 2.2 • Directivity index (DI): 3.4 dB • Rated maximum SPL (1m): 105 db continuous, 111 dB peak • Rated impedance: 8 ohms • Transformer taps: (70V) 30W, 15W, 7.5W, 3.8W; (100V) 30W, 15W, 7.5W • Transformer insertion loss: <1 dB, at any tap setting • Recommended protective high-pass filter: 65 Hz, 24 dB/oct for 8 ohm operation; 60 Hz, 24 dB/oct at 30W tap setting; 50 Hz, 24 dB/oct at 15W, 7.5W, and 3.8W tap settings • Dimensions: 17" H x 11.5" W x 11.5" D (432 x 291 x 291 mm) • Item weight: 12 lbs. (5.5 kg).
Additional information and certifications: IP-55 rating per IEC529 (dust protected and protected against jets of water) • Exceeds MilSpec 810 for humidity, salt spray, temperature & UV • Passes Mil-STd-202F for salt spray • Enclosure UL94V0 rated • UL1480, transformer UL recognized per UL1876, ROHS compliant.
BrandJBL Professional
ModelControl 85M
Part Number246-8477
UPC691991005077
Weight16
ColorGreen
Configuration2-way
Input Rating8 ohm|70V|100V
Mounting StyleLandscape
Woofer Diameter5.25"
Special FeaturesWater Resistant-Weatherproof-UL1480
