  • JBL 2242H 18" Maximum Output LF Driver 8 Ohm
CLEARANCE JBL 2242H 18" Maximum Output LF Driver 8 Ohm
JBL ProfessionalPart # 294-485
Model: 2242H
The 2242H is ideal for use in high output subwoofer systems with bass extension to 25 Hz.
  • High output and low distortion
  • Massive excursion provides clean, deep bass
  • 4" edgewound aluminum ribbon voice coil
  • SFG&#153 magnet structure with Super Vented Gap&#153 (SVG) cooling technology
We'll send you an email when JBL 2242H 18" Maximum Output LF Driver 8 Ohm is back in stock or available for preorder.
The 2242H is ideal for use in high output subwoofer systems with bass extension to 25 Hz. The total peak-to-peak excursion of the 2242H is 18 mm, within 10% linearity. The Super Vented Gap™ (SVG) series of low frequency transducers takes the patented Vented Gap Cooling™ (VGC) heat dissipation process one step further. A completely new motor structure design extends the pole piece above and below the top plate to improve gap flux symmetry and increase thermal conductivity from the voice coil to the pole piece. In addition to the benefits of Symmetrical Field Geometry™, these transducers also incorporate a copper shorting ring that is imbedded in the pole piece at the precise center of the gap and in close proximity to the voice coil. This ring results in a reduction of third harmonic distortion and a reduction of voice coil inductance, which improves the transducers' transient response.
BrandJBL Professional
Model2242H
Part Number294-485
UPC844632066955
Weight35.5
Nominal Diameter18"
Power Handling (RMS)800 Watts
Power Handling (MAX)1600 Watts
Frequency Response25 to 1,600Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)4.7Ω
Voice Coil Inductance (Le)1.25mH
Mechanical Q (Qms)5
Electromagnetic Q (Qes)0.29
Total Q (Qts)0.28
Compliance Equivalent Volume (Vas)10ft³
BL Product (BL)23.7T·m
Maximum Linear Excursion (Xmax)9mm
Surface Area of Cone (Sd)1238.71cm²
Cone MaterialPaper
Overall Outside Diameter18.25"
Baffle Cutout Diameter16.85"
Depth8"
Sealed Volume1.28ft³
Sealed F3102Hz
Vented Volume2.52ft³
Vented F365Hz
