  • In-line Mini Blade ATM Fuse Holder with 16 AWG Wire Leads
Parts ExpressPart # 070-676
Protect your electronic equipment indoors or outdoors with this 16 AWG in-line ATM blade type fuse holder.
  • Weather resistant cap seals out moisture
  • Uses standard ATM mini blade type fuses used in most new vehicles
  • 105°C 600 volt wire rating enables it to be used in multiple applications
Your Price: $1.99
MSRP: $2.99
Save $1.00 (33%)
Quantity:Qty: 1-9 $1.99/ea
Quantity:Qty: 10+ $1.79/ea
952 In Stock
We'll send you an email when In-line Mini Blade ATM Fuse Holder with 16 AWG Wire Leads is back in stock or available for preorder.
The in-line ATM fuse holder saves space over the ATC fuse holder. Most new cars use the mini blade type fuse to save space in fuse panels. That makes the ATM fuse holder the better choice when protecting your equipment under 20 amps. You may already have extra fuses for your car to install in this fuse holder plus save space when installing it under the dash, in the trunk, in the boat, or on an ATV. The ATM in-line fuse holder's weather resistant design enables it to be installed outdoors for multiple applications including lawn equipment.
Specifications: • Body size: 1" H x 0.44" D x and 1.6" W at the base including strain reliefs • Wire Size: Two 5.9" L X 0.12" Dia. with jacket • Wire gauge: 16.
Part Number070-676
UPC848864034973
