  • In-line Mini Blade ATM Fuse Holder with 12 AWG Wire Leads
Parts ExpressPart # 070-678
Heavy duty, in-line fuse holder for ATM blade type fuses with weather resistant cap.
  • Weather resistant cap seals out moisture
  • Uses standard ATM mini blade type fuses used in most vehicles
  • 105°C 600 volt wire rating enables it to be used in multiple applications
Your Price: $2.57
MSRP: $3.99
Save $1.42 (36%)
425 In Stock
We'll send you an email when In-line Mini Blade ATM Fuse Holder with 12 AWG Wire Leads is back in stock or available for preorder.
Order in the next 4 hr 6 min to ship today. Details
The in-line ATM fuse holder saves space over the ATC fuse holder. Most new cars use the mini blade type fuse to save space in fuse panels. That makes the ATM fuse holder the better choice when protecting your equipment under 30 amps. You will have spare fuses for your car plus save space when installing this in-line fuse holder under the dash, in the trunk, in the boat, or on an ATV. The ATM in-line fuse holder's weather resistant design enables it to be installed outdoors for multiple applications including lawn equipment.
Specifications: • Body size: 1" H x 0.44" D x and 1.6" W at the base including strain reliefs • Wire Size: Two 5.9" L X 0.15" Dia. with jacket • Wire gauge: 12.
Part Number070-678
UPC848864034980
