  • In-line Maxi Blade Fuse Holder with 8 AWG Wire Leads
Parts ExpressPart # 070-682
Protect your outdoor and high amperage equipment with this weather resistant maxi blade in-line fuse holder.
  • Water resistant design makes it ideal for multiple applications
  • Holds standard size max or maxi blade type fuses
  • 150 mm 8 gauge tinned copper wires on each side for easy hook-up
Your Price: $6.30
MSRP: $7.99
Save $1.69 (21%)
1185 In Stock
We'll send you an email when In-line Maxi Blade Fuse Holder with 8 AWG Wire Leads is back in stock or available for preorder.
Order in the next 0 hr 42 min to ship today. Details
This fuse holder works great for high amperage electronics in boats, ATVs, RVs, and other outdoor equipment. The weather proof cap keeps moisture out and the 8 gauge tinned wire is made for extreme conditions. Blade type fuses have become more popular because they are easier to change, safer to handle, and more weather resistant then glass type fuses. Mini and ATC blade type fuse holders can't handle more than a 40A fuse, so this maxi blade type fuse holder with 8 AWG wire works perfect for high power amplifiers and other high current electronics under 80 amps.
Note: Before installing the in-line maxi fuse holder, slightly pry open the fuse sockets before installing the fuse for the first time.
Specifications: • Body size: 2" H x 0.66" D x and 3.1" W at the base • Wire Size: Two 5.9" L X 0.25" Dia. with jacket • Wire gauge: 8.
Part Number070-682
UPC848864035000
Weight0.2
