  • In-Wall Speaker Pre-Construction Bracket Pair 7-7/16" X 10-13/16" Opening
BUYOUT In-Wall Speaker Pre-Construction Bracket Pair 7-7/16" X 10-13/16" Opening
Parts ExpressPart # 269-2291
Constructed from durable ABS and designed for installation prior to drywall, this bracket streamlines the process of adding in-wall speakers. Simply position and level the bracket at the desired speaker location, run the speaker wires to the same point, and later use the bracket as a precise cutout template once the walls are finished. The result is a clean, accurate, and hassle-free in-wall speaker installation that saves time while ensuring professional-looking results.
  • Constructed from durable ABS for long-lasting reliability and stability
  • Designed for installation before drywall to simplify the in-wall speaker setup process
  • Easy to use—just position, level, and run speaker wires to the desired location
  • Doubles as a precise cutout template once walls are finished, ensuring a clean, accurate, and professional-looking installation
BUYOUT $9.98
Save $10.01 (50%)
We'll send you an email when In-Wall Speaker Pre-Construction Bracket Pair 7-7/16" X 10-13/16" Opening is back in stock or available for preorder.
Order in the next 9 hr 42 min to ship today. Details
  • Overall Width (including mounting wings): 29-1/2"
  • Overall Height: 12"
  • Bracket Thickness: 3/4"
  • Maximum Speaker Cutout: 10-13/16"H x 7-7/16"W
Part Number269-2291
UPC848864081526
Weight1.65
