  • IP67 Dual Weatherproof RJ45 Female to Female Coupler
Parts ExpressPart # 090-984
This connector is ideal for coupling two RJ45 cat 5e patch cables inside a weatherproof UV stable housing. Dalco# 62302
  • Chassis mount screw-on connector for quick installation
  • UV stable housing will not crack or fade
  • IP67 waterproof rating
  • Rubber boot has a small slit for installing premade cables without cutting the end off
Your Price: $12.98
MSRP: $22.99
Save $10.01 (44%)
77 In Stock
We'll send you an email when IP67 Dual Weatherproof RJ45 Female to Female Coupler is back in stock or available for preorder.
Order in the next 10 hr 26 min to ship today. Details
It can adapt to existing network cables such as UPT, STP or FTP RJ45 cables. An internal gasket creates a weatherproof connection and a round boot wraps around the premade cable to seal out water. With an IP67 waterproof rating, it can withstand dusty environments and immersion of water and other corrosive elements. The UV stable housing will not crack or fade from direct sunlight.
Specifications: • Housing dimensions: 3.6" L x 1.25" Dia.
Part Number090-984
UPC848864040042
Weight0.1
