  • AC Power Cord CEE 7/7 to IEC-320-C13 18 AWG 2C 10A SPT-2 125V Black 6 ft.
Parts ExpressPart # 110-110
Premium heavy-duty 1.0mm² gauge (European standard) European AC power cord. Connectors: 2-prong CEE 7/7 European male supply end to 3-pin IEC-320-C13 female equipment end.
  • 32 strands of 32 gauge wire = 17 gauge US standard
Your Price: $6.98
Save $2.01 (22%)
We'll send you an email when AC Power Cord CEE 7/7 to IEC-320-C13 18 AWG 2C 10A SPT-2 125V Black 6 ft. is back in stock or available for preorder.
Estimated back in stock 7/24/2026
Premium heavy-duty 1.0mm² gauge (European standard) European AC power cord. Connectors: 2-prong CEE 7/7 European male supply end to 3-pin IEC-320-C13 female equipment end. Female connector plugs directly into device, and male connector plugs into European outlet. Ideal for electronic equipment, computers, and peripherals. CE and VDE certified. Rating: 10 amps. Length: 6 ft. Color: Black.
NOTE: This cable does not convert voltages, it only adapts an IEC device to be able to plug into a European type receptacle. Therefore, before using this product, verify your device has the ability to work with the voltage coming from the wall plate.
Part Number110-110
UPC844632082702
Weight0.45
Equipment/Device End (Load)IEC C13
Wall/Outlet End (Source)EU CEE 7/7
Wire Gauge16/3
