CLEARANCE ICEpower 200AC Class D Audio Amplifier Module 1 x 200W
- Powered by 200ASC and 500ASP eliminating additional power supplies
- ICEpower's patented COM modulation and MECC control techniques ensure excellent audio performance
The ICEpower 200AC is a "hanger" amp module powered by the ICEpower DC Bus integrated in the ICEpower 200ASC and 500ASP amp modules. These two amp modules handle up to two additional ICEpower200AC amplifier modules from the integrated power supply. This full compatibility with the ICEpower200AC modules offers a flexible and powerful building block concept for multi-way and multi-channel audio system design.
Note:Requires the 326-142 ICEpower Amplifier Module 200AC Wiring Harness Kitto attach to the 200ASC amp board (sold separately).
Specifications: • Wattage output: 1 x 200W RMS @ 4 ohms 0.2% THD+N, 10-20,000 Hz • Frequency response: 10-20,000 Hz all loads • Dynamic range: 110 dBA • Total efficiency: 79% @ 200W 4 ohm • Input voltage: 47 VDC • Maximum output current limit: 12.5A • Dimensions: 4.23" W x 2.2" D x 1.5" H.
Product Details | |
| Brand | ICEpower |
| Model | 200AC |
| Part Number | 326-210 |
| UPC | 848864053837 |
| Unit of Measure | Each |
| Weight | 0.55 |
Product Specifications | |
| Board Type | 1 Channel Mono Amp |
| Power (RMS/Channel 8 ohms) | 51 - 100 Watts |
