  • Home Theater Four 0.5m RGB LED TV Backlight Strip Kit with RF Remote 5V USB Powered
CLEARANCE Home Theater Four 0.5m RGB LED TV Backlight Strip Kit with RF Remote 5V USB Powered
Parts ExpressPart # 073-308
This four 0.5m RGB 5050 LED backlight strip kit is an easy solution to adding color customization and accent lighting into your home theater room or office. The included RF remote enables you to quickly choose between 16 colors and 4 dynamic modes.
  • Reduces eye strain when watching TV in a dark environment
  • Illuminates the surroundings without reflecting on the screen
  • Improves the TV's perceived contrast ratio
  • Dust and humidity proof
  • USB TV power eliminates the need for a wall socket
  • Max current draw 7.2W/m
  • Includes RF remote for easy color change and dimming options
CLEARANCE $12.98
MSRP: $32.99
Save $20.01 (61%)
Out of Stock
We'll send you an email when Home Theater Four 0.5m RGB LED TV Backlight Strip Kit with RF Remote 5V USB Powered is back in stock or available for preorder.
This item is no longer available
This home theater backlight kit allows you to easily add LED accent lighting for decoration and fun, jazzing up your home theater room, game room, or living room with a splash of color. The package includes four 0.5 meter RGB LED strips, three 36 mm extension cables, 10 male to male 4-pin connectors, controller, RF remote, and a 0.5m USB cable. The flexible adhesive strips stick right to the back of your TV and the 36 mm extensions enable you to separate the four 0.5m LED TV. The RF remote control quickly chooses between 16 colors and 4 dynamic modes to match your mood. Using LED strips as a backlight for TV provides enough light for your eyes to get their color reference, and creates a crisper, more vivid picture. Plug the USB cable into a powered socket with at least 2.4A if you plan to use white in full brightness mode.
The unique design of this RGB LED kit enables you to separate the four strips into various patterns. USB power enables the strips to be used in multiple applications. Light them up under the dash or in a trunk quickly by plugging them into a vehicle's USB auxiliary power socket. USB battery bricks enable you to use them in portable 5 VDC electronic projects, camping, or other outdoor activities. Put some excitement into your next event, or project with these USB powered RGB LED lights.
*Note: Check TV's USB current output before using its port. This strip draws over 2A in white mode at full brightness.
Specifications: • Input: 5 VDC (via USB) • Max current draw 2.8A • LED strip dimensions: Four 19-5/8" L x 7/16" (0.5m x 11.24 mm) W • USB cable length: 19.5" (0.5m) • Length with all the LED strips and extensions put together 6.9 ft. (2.108m).
Part Number073-308
UPC848864049496
Weight0.5
