  • 1500 Watt Dual-Mode Heat Gun with LCD Display and Variable Temperature
CLEARANCE 1500 Watt Dual-Mode Heat Gun with LCD Display and Variable Temperature
Parts ExpressPart # 370-365
LCD temperature controlled heat gun for a multitude of projects and applications. With temperatures ranging from low 212 ~ 572°F to high 572 ~ 1202°F, and an automatic shut-off to prevent overheating, two reducers and a reflector, this heat gun is a must have for the professional or hobbyist.
  • Input power: 750W/1500W low to high
  • Air flow: 450L/min
  • Increase and decrease temperature by 10 degree increments
  • Includes reducer nozzles and reflector nozzle
  • LCD temperature display
CLEARANCE $19.62
MSRP: $65.99
Save $46.37 (70%)
20 In Stock
We'll send you an email when 1500 Watt Dual-Mode Heat Gun with LCD Display and Variable Temperature is back in stock or available for preorder.
Order in the next 3 hr 21 min to ship today. Details
With the flip of the switch this heat gun goes from low to high air volume, that's where similarities end. Unlike traditional heat guns, this unit allows you to set the temperature anywhere from 212 ~ 1202°F in 10° increments. Low power and low velocity temperature range from 212 ~ 572°F; high power and high velocity temperature range from 572 ~ 1202°F. Temperature is adjusted by simply pressing the up/down buttons underneath the LCD display. Two reducers and a reflector allow you to use this heat gun for many projects.
Part Number370-365
UPC848864014609
Weight2.15
