  • Dalco High Speed USB 2.0 Active Extension Cable 16 ft.
CLEARANCE Dalco High Speed USB 2.0 Active Extension Cable 16 ft.
Dalco ElectronicsPart # 73406
Model: 519779
This 16-foot USB A 2.0 male to female active repeater cable is a bus powered extension cable that can be used to increase the length of a device cable without signal loss and potential performance problems.
CLEARANCE $12.47
Save $6.52 (34%)
9 In Stock
We'll send you an email when Dalco High Speed USB 2.0 Active Extension Cable 16 ft. is back in stock or available for preorder.
This 16-foot USB A 2.0 male to female active repeater cable is a bus powered extension cable that can be used to increase the length of a device cable without signal loss and potential performance problems. USB limits a cables length to 16 feet. Any length above 16 feet requires the use of an active repeater that has a signal booster built in. The overall cable length can be extended up to 75 feet by daisy chaining up to 5 of these repeaters. Data transfer up to 480 Mbps.
BrandDalco Electronics
Model519779
Part Number73406
UPC848864041032
Weight0.45
