  • HDMI 4K2K Audio Signal Inserter
CLEARANCE HDMI 4K2K Audio Signal Inserter
Parts ExpressPart # 180-1136
Add a separate optical or analog audio input signal to any HDMI video while cancelling the original audio with this 4K2K audio inserter.
  • Integrates audio and DVI (with DVI to HDMI adapter) video to HDMI signal output
  • Supports HDMI audio sampling rate up to 192 kHz and optical S/PDIF up to 48 kHz
  • Receives and delivers 4K2K resolution and 3D signal
CLEARANCE $22.46
MSRP: $54.99
Save $32.53 (59%)
3 In Stock
We'll send you an email when HDMI 4K2K Audio Signal Inserter is back in stock or available for preorder.
Use this HDMI audio inserter to add audio to DVI videos or to replace audio on an HDMI video. Many videos and slide shows taken from smartphones or digital cameras have no sound, or background sounds that are not needed. Using this audio inserter you are able to add your own voice or play background music that fit with the theme of the video or slide show. This works great when you're doing a presentation and you want to narrate the event that's going on in the video.
The audio inserter has a front panel three position switch that enables you to add new audio or keep the original HDMI audio. Switch between HDMI, optical, or L/R analog audio without having to physically change cables or components. This makes it perfect for church sound booths, home theater setups, and conference rooms.
Specifications: • Video compliance: HDMI, HDCP 1.2 and DVI1.0 • Maximum input/output cable length: 15 meters 1080p at 8-bit resolution or 10 meters 1080p at 12-bit resolution • Resolution: Up to 4K2K and 3D • Included power supply: 5 VDC 2A with 1.3 x 3.5 mm tip + plug • Dimensions: 4" W x 3-1/4" D x 1" H.
Part Number180-1136
UPC848864059150
Weight0.8
