  • HDMI 2.0 Splitter 1x2 with HDCP 4Kx2K 60 Hz with EDID
CLEARANCE HDMI 2.0 Splitter 1x2 with HDCP 4Kx2K 60 Hz with EDID
Parts ExpressPart # 180-1144
Split your Full HD 4K @ 60 Hz signal without losing speed with this HDMI 2.0 2-way splitter.
  • Supports full HD up to 4K @ 60 Hz with 12-bit deep color
  • Supports compressed audio such as DTS, Dolby Digital (including DTS-HD Master Audio™ and Dolby TrueHD) and LPCM 7.1 CH uncompressed audio
  • Bandwidth 600 MHz/6 Gbps per channel up to 18 Gpbs all channels
  • Compliant with HDCP Rev 1.4/2.2 specifications
We'll send you an email when HDMI 2.0 Splitter 1x2 with HDCP 4Kx2K 60 Hz with EDID is back in stock or available for preorder.
This 2-way HDMI 2.0 splitter distributes the input of the HDMI signal into 2 outputs simultaneously. It supports Full HD, 3D, and output resolution 480, 576, 720, 1080, 2K, and 4K @ 60 Hz. The splitter also supports standard audio, DSD, and HBR. Put it all together with 18Gpbs bandwidth speed for the most amazing picture and sound quality split into two different 4K Ultra HD TVs viewable at the same time. The HDMI splitter includes a 5 VDC power supply that makes it plug-and-play right out of the box.
Part Number180-1144
UPC848864061665
Weight0.7
Audio Input/OutputHDMI
Video Input/OutputHDMI
