  • HDMI 2.0 Premium 4K 60 Hz 1-Input 4-Output HDCP 2.2 Amplified Splitter
CLEARANCE HDMI 2.0 Premium 4K 60 Hz 1-Input 4-Output HDCP 2.2 Amplified Splitter
Parts ExpressPart # 180-1112
Split your Full HD 4K @ 60 Hz signal without losing speed with this HDMI 2.0 4-way splitter. Even if you don’t require 4K video today, the V2.0 HDMI Splitter 1×4 ensures you’ll be ready to take advantage of tomorrow’s display technology.
  • Speedy data transfer rates up to 6.0 Gbps per channel (18 Gbps all channels)
  • Full HD up to 4K @ 60 Hz YUV 4:4:4 with 8/10/12 bit deep color delivers maximum HDMI 2.0 picture quality
  • V2.0 and backwards compatible with the earlier versions
  • Audio formats DTS-HD/Dolby-true HD/LPCM 7.1/DTS /Dolby-AC3/DSD for theater quality sound
  • Supports both HDCP 2.2 and HDCP 1.4
CLEARANCE $29.25
MSRP: $85.99
Save $56.74 (66%)
4 In Stock
We'll send you an email when HDMI 2.0 Premium 4K 60 Hz 1-Input 4-Output HDCP 2.2 Amplified Splitter is back in stock or available for preorder.
The HDMI splitter 1×4 lets you share four HDMI displays or projectors with an HDMI-enabled audio/video source device. With support for Ultra HD (4K @ 60Hz) the HDMI splitter ensures astonishing picture quality, four times the resolution of HD 1080p @ 60 Hz. The 4K splitter is also backward compatible with previous HDMI revisions, supporting 1080p/720p HDMI video resolution devices. The splitter's small 6.06" x 2.72" x 0.91" (154 x 69 x 23 mm) metal housing hides well behind TVs or TV stands.
Features: • Supports HDMI 2.0 and 3D video • HDCP 2.2, 1.4 compliant • Bandwidth: 6.0 Gbps per channel, 18 Gbps total • Supports deep color 8/10/12 (36 bit all channels) • Supports resolution up to 4096 x 2160 @ 60 Hz • Supports DTS, Dolby Digital (DTS-HD Master Audio, Dolby True-HD) compressed audio formats and uncompressed such as LPCM • Supported Cable Length(AWG26 standard HDMI Cable): Input ? 49 ft., output ?82 ft. (with/under 1080p resolution); Input ? 39 ft., output ? 49 ft. (with 4k resolution).
Part Number180-1112
UPC848864056685
Weight1
