  • HDMI 2.0 4K 60 Hz Extender Over Cat6 Cable 200 ft. (60m) Extra Receiver
CLEARANCE HDMI 2.0 4K 60 Hz Extender Over Cat6 Cable 200 ft. (60m) Extra Receiver
Parts ExpressPart # 184-502
This additional receiver attaches to the receiver in the 184-500 kit for additional 4K video viewing up to 200 ft. away via Cat6 cable. It also extends the IR remote signal if needed.
  • Supports HDMI V2.0, up to 4K @ 60Hz 4:4:4, DDR 10, 18G, HDCP2.2/1.4 for versatility
  • Extends 4K video up to 200 ft. away via Cat6 cable from another receiver
  • Features visually lossless compression with no latency
  • Extra receiver gets its power through PoC which elimates the need for extra AC adapters
  • Bi-directional IR pass through extends remote control from source or display
CLEARANCE $39.09
MSRP: $79.99
Save $40.90 (51%)
6 In Stock
We'll send you an email when HDMI 2.0 4K 60 Hz Extender Over Cat6 Cable 200 ft. (60m) Extra Receiver is back in stock or available for preorder.
Enjoy 4K @ 60 Hz 4:4:4: video resolution up to 200 ft. away from another receiver with no video delay using this HDMI 2.0 extra receiver over Cat6. Running long distance HDMI cables without reducing video quality has always been problem. All the video source equipment needs to be in the back and the screens need to be in the front or in another room. Other Cat6 extenders only offer one receiver to go to one video display. That's why this HDMI 2.0 extra receiver eliminates that issue when adding it to the 184-500 HDMI 2.0 extender kit. Add up to seven extra receivers to the 184-150 extender kit for viewing up to eight TVs. Each extra receiver works up to 200 ft. from the previous receiver. All the extra receivers don't need any AC power because of the PoC function.
Part Number184-502
UPC848864063669
Weight0.95
