  • HDMI 2.0 4K 60 Hz 1-Input 2-Output HDCP 2.2 Splitter
CLEARANCE HDMI 2.0 4K 60 Hz 1-Input 2-Output HDCP 2.2 Splitter
Parts ExpressPart # 180-1109
Split your Full HD 4K @ 60 Hz signal without losing speed with this HDMI 2.0 2-way splitter.
  • Supports full HD up to 4K @ 60 Hz 4:4:4: chroma with 12-bit deep color
  • Supports compressed audio such as DTS, Dolby Digital (including DTS-HD Master Audio™ and Dolby TrueHD) and LPCM 7.1 CH uncompressed audio
  • Bandwidth 600 MHz/6 Gbps per channel up to 18 Gpbs all channels
  • Compliant with HDCP Rev 1.4/2.2 specifications
  • Pass atoms and Dolby vision for extra versatility
CLEARANCE $29.07
Save $17.92 (38%)
39 In Stock
We'll send you an email when HDMI 2.0 4K 60 Hz 1-Input 2-Output HDCP 2.2 Splitter is back in stock or available for preorder.
This 2-way HDMI 2.0 splitter distributes the input of the HDMI signal into 2 outputs simultaneously. It supports Full HD, 3D, and output resolution 480, 576, 720, 1080, 2K, and 4K @ 60 Hz. The splitter also supports standard audio, DSD, and HBR. Put it all together with 18Gpbs bandwidth speed for the most amazing picture and sound quality split into two different 4K Ultra HD TVs viewable at the same time. The HDMI splitter includes a 5 VDC power supply that makes it plug-and-play right out of the box. The output quality depends on the source. Both TVs must be 4K 60 Hz or the output quality will drop down to the lowest resolution TV.
Part Number180-1109
UPC848864063676
Weight0.5
