  • CAIG Gx3 Electronics / Equipment Cleaning Fluid 236ml/8oz
CLEARANCE CAIG Gx3 Electronics / Equipment Cleaning Fluid 236ml/8oz
CAIG LaboratoriesPart # 341-264
Model: CL-ECP-08
Are you looking for a safe and effective way to clean your turntable dust covers, speakers, and other audio equipment? Look no further than Caig GX3 equipment cleaning solution! Designed to clean sensitive surfaces, this anti-static solution and microfiber cloth combo is a must-have for audio enthusiasts.
  • Cleans without scratching or clouding clear plastic turntable covers
  • Anti-static properties help repel dust
  • Safe for wood, plastic, metal and glass surfaces
CLEARANCE $14.50
MSRP: $17.95
Save $3.45 (19%)
5 In Stock
We'll send you an email when CAIG Gx3 Electronics / Equipment Cleaning Fluid 236ml/8oz is back in stock or available for preorder.
When it comes to cleaning your precious audio gear, it's crucial to use a product that won't cause any damage or leave behind residue. Caig GX3 is specially formulated to gently remove dust, fingerprints, and other debris without harming delicate surfaces. Its anti-static properties help repel dust, ensuring a long-lasting clean look for your equipment.
The included microfiber cloth is specifically designed for use with the GX3 solution. Made of ultra-soft fibers, it effectively captures and traps dirt particles instead of pushing them around. This ensures a thorough and streak-free cleaning experience. Plus, the cloth is machine washable, so you can use it repeatedly without worrying about losing its cleaning power.
To clean your turntable dust cover, simply spray a small amount of GX3 solution onto the microfiber cloth and gently wipe the surface. For speakers and other audio equipment, lightly dampen the cloth with the solution and wipe away any dirt or smudges. The solution dries quickly and leaves no residue behind, giving your equipment a polished and refreshed look.
It's worth noting that Caig GX3 is safe to use on most surfaces commonly found in audio equipment, such as plastic, metal, wood, and glass. However, we always recommend testing a small, inconspicuous area first to ensure compatibility.
Maintaining the cleanliness of your audio equipment not only enhances its visual appeal but also ensures optimal performance. Dust and debris can affect sound quality and even damage sensitive components over time. By regularly cleaning with Caig GX3, you can keep your equipment in top shape and enjoy the best audio experience possible.
So why wait? Give your turntable dust covers, speakers, and other audio equipment the care they deserve with Caig GX3 equipment cleaning solution. Experience the peace of mind knowing that you are using a safe and effective product to keep your gear looking and sounding its best. Get yours today and make cleaning a breeze!
BrandCAIG Laboratories
ModelCL-ECP-08
Part Number341-264
UPC697429019241
Weight0.65
