Normal utility knives are usually too small to keep a tight grip on, or the blades break or slide out when too much pressure is put on them. You won't have these problems with this jumbo utility knife. The Grip Tools jumbo heavy-duty utility knife comes with a large rubber coated 6" handle, five thick sharp blades, and a blade lock. An easy slide pushbutton lets you extend and retract the blade to the right length to get the job done.
Specifications: • Knife dimensions: 7-3/4" L x 2" H x 1" D • Blade dimension: 5" L x 1" H x 0.03" D.
