  • Goldwood TR-69 6"x9" Sealed Box Pair
GoldwoodPart # 260-654
Model: TR-69
Perfect for installing 6" x 9" speakers in your vehicle, these wedge boxes are made with 1/2" industrial grade particleboard and covered with charcoal gray carpet. Threaded knob terminals are included. Dimensions: 12.75" W x 8.25" H x 7.25" D x 6.25" D (tapered). Internal volume is .22 cu. ft..
Your Price: $51.98
Save $16.01 (24%)
We'll send you an email when Goldwood TR-69 6"x9" Sealed Box Pair is back in stock or available for preorder.
Just connect your wires, drop in your woofers, and you're good to go!
Check your available space—each enclosure measures 8.5" x 12" x 6.75" (H x L x D)
The front panel is angled for woofer mounting, with a flat rear surface measuring 2"
Woofer openings are 6" x 8.75" with a 4.5" mounting depth
Features gold-plated binding posts with raw wire inputs and included wire leads
Constructed from high-quality CARB-compliant MDF with black aviation-style carpet
Enclosure has a 0.2 cu. ft. internal volume, a 0.625" thick baffle, and arrives fully assembled
BrandGoldwood
ModelTR-69
Part Number260-654
UPC086429143122
Unit of MeasurePairs
Weight9.7
